Results 1 to 10 of 43
Thread: use of liquid chlorine in AG vinyl lined pool
    May 2012
    Florida
    Default Re: use of liquid chlorine in AG vinyl lined pool
    aylad - my pump has been running 24/7 with no real increase in preassure. im at 2 PSI with the pump running on low. i have not cleaned the filter since last weekend and PSI is still at 2. i suspect i have a bad filter ( i should have one delivered this week ). there has been some more improvement in water clarity, but i sill cant see the bottom. water is blue.
    i tested FC this morning and its over 5 but by how much i dont know ( still waiting on the K-1515 ) ill test again late in the day and post. yesterday morning i was between 1.5 and 2 FC so im holding much more overnight!
    18' round 7.5K gal AG vinyl pool; bleach; waterway cartridge filter; waterway pump; 12hrs; taylor k-2005 and taylor k-1515a; utility water ; summer: none; winter: none; ; PF:16
    May 2012
    Florida
    just tested...
    FC 5
    TC 5 no change in color after adding the 5 drops of R-003, so is my TC 5 or 10? taylor kit says subtract FC from TC to get CC
    PH 7.4
    ALK 100
    just added 1.42 gal of bleach, and ill add another 1.42 gal in a little while. i guess im on the right track here right? im holding more chlorine over night and loosing less during the day... i have only been adding the chlorine at night, but not during the day, am i doing this right?
    i stopped by my local chemical "pusher" today. the only thing i bought was a 60ml bottle of R-0013 and a pack of those skimmer socks ive been reading about. i fitted two socks to my skimmer basket to see if this helps clear things up untill the new filter gets here. while there the "pusher" asked me if i had a sample of water that needed to be tested since he knows i was fighting algae, but i of coarse did not... then he asked if i "needed" anything and kinda winked at me. my answer was no. no shock, pucks, or algaecide? i said nope. a clarifier perhaps? again i said nope. i quickly paid for my reagent and socks and high tailed it out of there all the while looking over my shoulder to make sure no one was following me..... i almost caved, he almost had me when he said the word "clarifier" after all my water is still cloudy, i almost fell off the wagon my friends. i didnt have the heart to tell him that the jig is up! im off the hard stuff and on the BBB...!
    BigDave's Avatar
    Hi,
    My name is Darkside and I've been BBB for almost a week.
    Hi Darkside!
    May 2012
    Florida
    got my K-1515A today!
    so do i do the .2 or .5 test to read up to around 25/30ppm since thats what im shocking up to.
    May 2012
    Florida
    went ahead and played with my new chemistry set.
    using the K-1515 i tested a 10 ml sample. 2 spoons of R-0870 powder made the sample turn bright pink. 19 drops of R-0870 made the sample go from pink to clear. so, 19 x .5 = 9.5ppm FC right? i moved to step 5 and added 5 drops of R-0003 and sample didnt turn pink, so i didnt think i could move to step 6 since step 6 changes the sample from pink, back to clear. im confued with this part of the test.
    i also did a dilution test (4.5 ml tap water and 4.5 ml pool water) with the K-2005 DPD and it also comes out to 10ppm FC.
    PH is still 7.4 so, i added a couple of my "butter container scoops" that should get me back around 7.5-7.6 PH.
    im going to add more chlorine tonight, and i assume ill keep adding the 2 big jugs right, also water is still cloudy as i brushed all the goop from the pool floor yesterday afternoon.
    any ideas on whats up with the cloudy water? pump PSI is still 2 on low! cant wait to get the new filter! any ideas on why this cloudy water wont clear up?
    thanks for any help folks!
    When you add the scoops of powder, if one scoop turns it pink, you don't need the second scoop. You are correct that it would be a FC reading of 9.5. If you add the drops of R-0003 and it stays clear, then you have no CC which is a good thing. So, you were right to stop at that point. Just use the 10 ml sample to save on your reagents.
    Continue to keep the chlorine high. With that high CYA, 25ppm of chlorine is what you need. After you add the bleach this evening, wait an hour or so and test your chlorine. Then, tomorrow morning within two hours of sunrise, test the chlorine again. See how much chlorine you are losing overnight and report back. Continue to run your pump.
    May 2012
    Florida
    even if 1 scoop produces a light link?
    i seem to still be losing FC over night. last night i added chlorine, and took a measurment a little later and it was 20.5ppm. i then used the calculator and it said i needed 2 qrts 6 0z to get 25ppm, so i added that amount, checked later ( this was all late in the evening ) and i measured 19.5ppm. this morning i measured 15.5ppm, came home today and measured 10.5ppm. CC measured this afternoon is .5ppm
    so a while ago i added 1 big jug and measured 19.5ppm. according to the calculator i need 2 qrts 3 cups to get 25ppm. ive added all this bleach in the last hour and a half or so, so ill test FC in just a bit.
    i have been brushing the floor of the pool in the evening after adding my bleach.
    the good news is that the filter came today. its a baleen filter, i actually thought i was ordering some other named filter but this is what i got. does anyone know if these are good filters? its seems to have a better filter medium vrs the orginal factory one. i noticed that when i installed it it took a litte effort to install it onto the tube at the bottom of the filter housing, i remember that the factory one used to fit nice and snug, but not any more... anyways while testing this afternoon after it was in there for about 2 hrs i seemed to already be able to see some improvement in clarity! i have the pump running on low.
