Results 1 to 10 of 30
Thread: Kem Tek 338 vs Jack's Magic Purple Stuff in salt pool?
    Default Re: Kem Tek 338 vs Jack's Magic Purple Stuff in salt pool?
    All the products you mention are HEDP. Kem-Tek is a 20% concentration, but I don't know the concentrations in the Jacks' product. Other than impurities they should be identical . . . IF you can determine concentration.
    HEDP was developed by Monsanto as part of their "DeQuest" line. I'm not sure if they still make it; probably most of it is coming from Asia now, as chemical regulations make it extremely difficult to manufacture commodity chemicals profitably here in the US. Asian purities can be suspect, so the question is about quality control, but I doubt you're going to get good answers there.
    28 July 2012 update:
    HEDP
    Jack's Magic Blue Stuff (20% solution)
    Jack's Magic Purple Stuff (20% solution)
    Jack's Magic Pink Stuff (60% solution)
    ProTeam Metal Magic (30% solution)
    RamChem Ram Metal Hold ((60% solution? )
    Kem-Tek 338-6 Metal & Calcium Eliminator (20% solution)
    Haviland Stain & Scale Magic (30% solution? )
    Remember, though, manufacturers can change formulations without notice.
    Virginia
    Thanks Ben. As you well know it's frustrating trying to compare products with the lack of good information from manufacturers. While I was able to find Jack's Magic uses HEDP, like you I was unable to find the concentration.
    Do you, or anyone else here (chem geek?), have an idea of how HEDP behaves in a high TDS/salt environment? Is is simply a matter of having a high enough concentration of HEDP to be effective in such an environment?
    If you ask in a month, I might. I have Monsanto's Dequest tech bulletins, but what I don't have is time to dig them out right now.
    Virginia
    Thanks Ben. I'll bring up the question again in a month or so.
    I still need to get together the materials I need for the bucket test you suggested to see if I still have any metals in my pool. Hopefully I can try it this weekend.
    Just one bit of info I had to dig out: "The Pink Stuff" is 60% concentration; "Purple" and "Blue" stuff are both lower, maybe 20%
    Virginia
    Thanks Ben.
    Interesting. If I had to make a guess (completely uneducated), I would have thought the products designed for high TDS/salt pools would have been a higher concentration.
    Given the information you found, would you think that the 20% concetration Kem Tek product would be as effective as the Purple Stuff? Could there be something else in the Purple Stuff that makes it work better in a high TDS/salt pool?
    I've sent a couple emails to Kem Tek asking about using their product in a high TDS/salt pool, but they have not responded.
    1. I think you are confusing marketing with design; when product labels say "designed for X" it almost always means "designed to sell TO people with X", and not "designed by a team of engineers for optimal performance when X is present". I'm smirking, as I type this, but I'm perfectly serious in making the assertion.
    2. I doubt anyone has actually studied the effect of different concentrations of HEDP in salt water pools.
    3. I think 3 cups of the Kem-Tek product would perform identically to 1 cup of the Pink Stuff or 3 cups of the Purple or Blue Stuff.
  1. Jacks Purple Stuff Alternative
    By Simmons99 in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 09-01-2006, 12:58 AM
  2. Jacks Purple Stuff Alternative
    By Simmons99 in forum Pool Chemicals & Pool Water Problems
    Last Post: 08-30-2006, 03:53 PM
  3. Jack's Magic Purple Stuff for SWG?
    By johndoe74 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-16-2006, 04:24 AM
  4. Jack's Purple Stuff Questions
    By mkamp1515 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2006, 12:13 AM
  5. Jack's Magic Blue Stuff
    By EricH in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 05-15-2006, 04:27 PM
