Large solar cover question
I did search threads I really did, but I still have a few questions about solar covers/blankets.
I need to cover an in ground, “True L” liner pool that is 45’ (L) X 20’ (W). The “L” section (which is included in the 45’ length but not the 20’ width is about an incremental 12’ X 16’ to cover.
My questions.
1) Should I get a 45X20 cover for the largest section and have this on a roller?
2) Should I get the best ( commercial ?) reel I can afford due to the size? I saw one that said it could handle a cover up to 50’.
3) For the separate “L” sections should I just get a separate cover and let it float apart from the main cover? Don’t think I can attach it since the reel will be 20 feet.
4) How does a solar cover stay in the pool – i.e. not blow away? Does it stay attached to the reel when it’s in the water ?
5) How difficult do you think it would be to manage and store a beast like this?
thanks
NJ Pool: In Ground, 40,000 Gal vinyl liner, chlorinated using BBB, Gas Heated, DE Grid filtration.
FL Pool: 10K gal gunite, chlorinated with 3'' pucks, cartridge filter, spill over spa
