I have an in ground pool with a combined spa.
Found my main light was about 1/3 full of water and not working and my spa light was also out (no water in spa light). I replaced the main light bulb and the seal around it, but alas the light will still not light. I assume the water has caused an electrical issue and since the spa won't light either, it probably is not contained to just the main light canister (haven't replaced the spa light yet). What is typically the problem here (yes, I did check the breaker)? Is this something a weekend warrior can fix or do I need a professional? 120 V. and water do scare me.
thanks
