Results 1 to 10 of 11
Thread: New 15' x 48" Intex pool
    Jun 2012
    Houston, TX
    Default Re: New 15' x 48" Intex pool
    Not sure what was up with the chlorine test (I actually saw that number twice over two days), but now it is down to 0 ppm again. pH is still at 7.6
    TA on my fill water is about the same - 180 ppm
    CH is also about the same - 120 ppm
    The following details are from after I refilled the pool. I have the 1" trichlor tabs that I'm using and I put three in every other day when the first three have dissolved. On the 6th I noticed the chlorine was down to 0 so I added the last 2 cups of bleach I had. I added about 1/2 lb of KemTech stabilizer on the 7th, so that makes about 1 lb so far. I also lowered my pH with one small box of baking soda (can't remember how much that was). The water was really cloudy yesterday after we were in (I noticed the KemTech had dissolved really fast because my kids swim in circles to make a whirlpool). The pool was clearer this morning, but still cloudy.
    Any suggestions?
    Stefanie
    BigDave's Avatar
    What kind of chlorine test do you have?
    Lowering pH is done with muriatic acid (read the link in my sig) or dry acid. Baking soda raises alkalinity. Yours is already high, so I wouldn't add any more. Odds are pretty good that your cloudiness is either dead algae from the last bloom that just needs time to filter out, or possibly algae that didn't get killed off. Try measuring your chlorine at night after the sun is off the pool, and then measure it again in the morning before the sun hits the pool. Compare those two numbers, and it will tell you if you have algae still trying to bloom (there will be more than a 1 ppm difference in the numbers).
    Jun 2012
    Houston, TX
    I tested the chlorine and found it was the same evening to morning. So I believe this is dead algae. I have been running my filter nonstop for several days and it has cleared up some. I will keep working at it and hopefully it will eventually clear up.
    Thanks!
