I had to grin at this one; here at the PoolForum, your question is almost a setup for the punch line!
Yes, the 'right' way to collect a sample is to get water out of your pool, and take it into your kitchen . . . where YOU test it yourself, with a K-2006! That will give you much more consistent results!Anyway, here's my question: Is there a "right" way to collect a water sample, either for pool shop or home testing that promises the most consistent and accurate results?
Teasing aside, I've had neighbors collect ONE sample from one pool, split it amongst themselves, and then take the divided samples to their dealer, and present them as if they came from two or three pools: the results were STILL widely varying!
When you collect a sample, you really just need to watch for two things:
1. Invert the container and put it into the pool a few inches before righting it, so you collect from below the surface, instead of on the surface. (This mainly matters when there's a lot of 'goo' on the surface.)
2. Don't collect a sample from the stream of water returning to the pool via the eyeball.
The test kit page is linke in my signature -- the 'reviews' are really recommendations from me; the links are to Amazon, since you usually cannot buy these kits locally, and since I get a 4+% commission if you buy from Amazon instead of elsewhere. I think the kits are back in stock -- I know a few people paid too much for them, because EVERYTHING went out of stock at the regular sellers.over the Memorial weekend.
