Thread: Main Drain Failure?
    May 2012
    Tennessee
    Question Main Drain Failure?
    My pool has started losing water (about 4 inches a day (inground 16x36). I am watching to see where it ends, but there has developed over the last couple years a large stain around the main drain (see pics). This is not dirt and the surface is as rough as it looks (ie--very rough). The size of the stain has been growing each year. Has anyone seen this before? Is this main drain failure, or more likely a leak in the vinyl near the main drain?
    pictures:
    from
    As above, but with enhanced contrast:
    Detail
    ~22K gal 16x36 IG vinyl pool w deep end; Pentair Tagelus TA-60D; PF:5
    Default Re: Main Drain Failure?
    I can't tell for sure, but it looks like you have a badly wrinkled area of the liner (possibly from a leak eroding the surface UNDER the liner) coupled mustard algae that's accumulated in the wrinkles.
    Mustard algae will brush up, at least somewhat, into a greenish or yellowish cloud. But, the only way I know to leak-check a location like that is with SCUBA. Some guys can hold their breath -- but you have to be VERY still to check leaks in a location like that, and even those who are good breath holders usually can't be that still.
    May 2012
    Tennessee
    Thanks for the info. At the current rate of drainage, I shouldn't have to hold my breath at all in a few days.
    You might not want to let that happen by itself -- I'd call a pool builder or service guy. If it's leaking like you say, you're going to have to drain it and repair it anyhow -- and draining liner pools is pretty much a professionals-only task (yes, some amateurs succeed, but more end up destroying their liner!).
    And . . . that amount of water leaking through can substantially increase the difficulty of repairs to the subsurface.
  1. I can't get my main drain to prime
    By Zac851 in forum Pool Equipment & Operations
    Last Post: 05-21-2012, 03:49 PM
  2. Main drain valve
    By samtex in forum Pool Equipment & Operations
    Last Post: 07-21-2011, 06:07 PM
  3. I want suction from skimmers, main drain, AND spa drain - bad idea?
    By joelq in forum Pool Equipment & Operations
    Last Post: 05-03-2007, 08:17 PM
  4. Main Drain
    By bubsmit in forum Pool Equipment & Operations
    Last Post: 05-31-2006, 02:58 PM
  5. Main Drain
    By nicole712 in forum Pool Equipment & Operations
    Last Post: 05-18-2006, 01:56 PM
