Results 1 to 10 of 13
Thread: New Pool
    Jul 2011
    West Texas
    Default Re: New Pool
    Pools all clear. Finally got numbers right except ph. Waiting on better test kit to get better reading. Thanks for all the help. This board makes it lots easier for me since I'm about 80 miles from a pool store.
    Intex 18'X42" AG with swg. 2nd yr.
    BigDave's Avatar
    I love good news! Thanks for sharing. What is your pH?
    Jul 2011
    West Texas
    It's over 8 the best I can tell with the strips. I have put a couple pounds of stabilizer in a sock and it's almost gone. Di I need to add more?
    BigDave's Avatar
    Quote Originally Posted by White Gold View Post
    ...add more?
    I have to answer that with a question - sorry. Is your chlorine holding? Can you dose chlorine once a day and stay above the minimum on Ben's Best Guess Chart? 2 lbs of stabilizer should put your CYA between 35ppm and 40ppm. You should keep your FC between 3ppm and 6ppm at all times. Do not let it drop below 3ppm.
    As far as the pH goes, I don't trust the strip and high is safer than low so I wouldn't try to move it until you can get a better measure (k-2006 kit). In the meantime, try to find a source for muriatic acid and read Using Muriatic Acid to Safely Lower Your Pool's pH to learn how to use it.
    Jul 2011
    West Texas
    The kit is supposed to be here this week so I'll check it then. Chlorine is holding good even in our blazing sun and heat.
