Results 1 to 10 of 42
Thread: new to pool stuff
    Default Re: I'm still confused...
    If it was my pool and I had sparkling water, I probably wouldn't worry about CH of 400. That's not super high. In fact, the suggested level is 200-400. But, I would not use any cal-hypo and I would not let my TA and pH get high. Just my opinion.
    (Note to others reading --- vinyl pools do not need calcium 200-400.)
    Jun 2012
    dallas, tx
    Thanks.
    I had come to the same conclusion- that 400 was not too high to worry about. My CYA is 75 & I'm using about 182 oz. of bleach a day, sometimes a bit more (364 oz.). I have been thinking of raising the CYA a bit higher (85-90) to hopefully use less bleach as you had suggested a while back, since my pool gets full sun all day.
    What do you think?
    22'x40' rectangle 34K gal AG concrete pool; liquid bleach 6%; Nautilus Plus NSP 72, 00J DE filter; AO Smith, P4RA6G-188L, 2 hp pump; hrs; Taylor 2004B. Drops.; city of McKinney; PF:3.5
    If you are using that much bleach each day, you probably would do better with your CYA a little higher. Take it up slowly, though. Don't want to overshoot your target.
    You're only a couple of hours away from me, so my climate is much the same as yours--you'll find that you lose a LOT less chlorine if you'll bump your CYA up to 90 or so! That's where I keep mine--and my chlorine loss is only about2-3 ppm daily.
