Page 5 of 5 FirstFirst ... 3 4 5
Results 41 to 42 of 42
Thread: new to pool stuff
  1. #41
    Default Re: I'm still confused...
    If you are using that much bleach each day, you probably would do better with your CYA a little higher. Take it up slowly, though. Don't want to overshoot your target.
  2. #42
    You're only a couple of hours away from me, so my climate is much the same as yours--you'll find that you lose a LOT less chlorine if you'll bump your CYA up to 90 or so! That's where I keep mine--and my chlorine loss is only about2-3 ppm daily.
  1. Sandpaper like stuff on bottom of pool
    By motomomof2 in forum Dealing with Algae & Slime
    Last Post: 05-29-2013, 05:51 PM
  2. New to this pool stuff
    By Aneal74 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-05-2012, 04:18 PM
  3. Red stuff in my pool!
    By edlentz in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 08-11-2009, 12:53 PM
  4. Stuff in the pool.
    By deep_blue in forum Dealing with Algae & Slime
    Last Post: 05-06-2007, 06:55 PM
  5. Anyone tried that pool genie stuff ??
    By hancop in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-24-2006, 04:31 PM
