Results 1 to 10 of 42
Thread: new to pool stuff
    Default Re: I'm still confused...
    You want to be able to go 2 - 3 days without backwashing, before you add it to your skimmer.
    Jun 2012
    dallas, tx
    It has been a week since I added 12 lbs. granulated cyanuric acid + 1 gal. liquid Instant Conditioner. The granulated has finally dissolved & my CYA=32 (dot finally disappeared). I am using about 2 lbs. Cal-hypo/day to keep the FC=3-5. pH is holding steady at pH=7.6-7.8. Other results: CC=0-.5, TA=125, CH=500.
    Pool never looked better! Sparkling clean! Also, my filter only needs backwashing maybe once a week. What are your recommendations? Should I add more cyanuric?
    22'x40' rectangle 34K gal AG concrete pool; liquid bleach 6%; Nautilus Plus NSP 72, 00J DE filter; AO Smith, P4RA6G-188L, 2 hp pump; hrs; Taylor 2004B. Drops.; city of McKinney; PF:3.5
    You'll probably want the CYA closer to 50 to make it easier to keep chlorine in the pool. I'd quit using the cal-hypo. Your calcium hardness reading is getting pretty high and you may end up with some cloudy water issues. (Recommended level is 200-400 for a gunite pool. Vinyl pools don't need any.)
    As watermom said, stop the cal hypo because your calcium level is pretty high. You might want to consider dropping the TA down a bit (around 80 ppm) so yo don't accidentally create scaling conditions if for some reason the pH should spike (it does happen).
    Jun 2012
    dallas, tx
    Ok, I'll switch to bleach. How do I lower TA? Muriatic acid? How much?
    Please read the following links. I think they will answer your questions.
    Lowering Alkalinity Step-by-Step
    Using Muriatic Acid Safely
    Jun 2012
    dallas, tx
    A little more help needed, please.
    Today @ 11am: FC=5.5, pH=8, CYA=55, TA=75, CH=450. FC has been holding steady @ 4-6 by adding 182oz. bleach daily.
    I have been adding cyanuric to raise CYA to target of 80. Last addition was 4 lbs. on 6/28. Readings went from 35 on 6/27, 60 on 6/29, 70 on 7/2, 70 on 7/3, 60 on 7/4, 55 on 7/5.
    Am I doing the test wrong? I know it shouldn't drop. I have not backwashed. Added about 3-4 inches of water that disappeared very quickly. Suspect I may have a leak near surface. I have also been adding muriatic acid & aerating to lower pH & CH. pH has been @ 7.3-7.6 but I ran out of muriatic & it went up to 7.8-8.
    CH went from 500 on 6/28, 450 on 6/29, 400 on 7/1, 500 on 7/2, 450 on 7/3, 400 on 7/4, 450 on 7/5. I am using the 10ml. size test. It seems like the color starts to turn purple-ish at about 15 drops, but doesn't turn blue until 16-18 drops? Again, am I doing it wrong? I know I need to add more muriatic & cyanuric. What else do you recommend? I have set my targets at FC=5-10, pH=7.4-7.8 (after CH goes down), CYA=80-90, CH=200-400, TA=80. Are these reasonable targets?
