Thread: Leaky Pump..
    Sep 2011
    Central NJ
    Default Leaky Pump..
    Hey All,
    Just noticed this past weekend that there is a drip coming from under my pump. Drips right around where the basket part meets the motor. Its not coming from the cap nor the pipe going from the basket part up to the filter.
    No weird noises.. pressure remains as it was. Will probably wait till I close the pool to check it out if its not a big deal, but if its something of concern (besides water loss), ill figure out a way to take a look at it pronto.
    Any thoughts?
    24' Round 52" (44"/12450gal) Deep Namco Morada - ClearWater 22" Sand Filter - 1.5HP (SPL) Speck Pump - Taylor K-2006C Test Kit
    Default Re: Leaky Pump..
    Sorry for the delay in responding
    It sounds like a shaft seal leak and should be addressed SOONER than later! The water can get into the bearings and wreck the motor. I would advise you to change the shaft seal before too much damage is done.
    ABSOLUTELY what Waste said!! I ignored that small leak I had last year--and it cost me a few hundred dollars and two weeks of a green pool at the beginning of this season until I got the new motor in to replace the one that could have been saved, had I bought the $7.00 part and spent the 20 minutes it takes to replace it....
    Sep 2011
    Central NJ
    Thanks for the responses! Called the company we bought from and they said we can swap the unit out under warranty. Just have to figure out a way to get it out of there without draining the pool a few inches.
