Thread: Help cleaning up a pool, after algae
    Jun 2012
    Connecticut
    Default Help cleaning up a pool, after algae
    Before:
    After:
    Still very cloudy, can't see through.
    Used chlorine, levels are high but that's not what I'm worried about.
    Ph seems very low and alkalinity is not even on the scale (very low).
    How do I eliminate the cloudiness and fix those 2 levels.
    Make sure you look at the pictures, they might be distorted seeing as they were photomerged.
    Default Re: Help cleaning up a pool, after algae
    1. Add 20 Mule Team borax, 2 boxes per 10K gallons, slowly to the skimmer with the pump on. Retest pH after 2 hours of circulation. Repeat every 4 hours till your pH is above the minimum level, then continue with 1 box per 10K gallons, till your pH has reached 7.4. Do NOT worry about alkalinity now.
    2. Use this form to give us the info we need to make recommendations about YOUR pool:
    Pool Chart Entry Form
    Pool Chart Results
    3. Add 4 gallons of PLAIN 6% household bleach to your pool, per 10K gallons, and then BRUSH the pool completely, to make sure that the piles shown on the bottom in the first pic are dead.
  1. Cleaning up algae and water mold in a Intex AG pool after vacation
    By strat in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-04-2013, 06:03 PM
  2. Cleaning algae with a new cartridge filter
    By RMA127 in forum Pool Equipment & Operations
    Last Post: 06-04-2012, 12:15 PM
  3. Where to go with cl level while cleaning pool
    By keastman in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 03-31-2012, 05:45 PM
  4. cleaning up the mustard algae
    By klasikal88keys in forum Dealing with Algae & Slime
    Last Post: 08-10-2006, 03:12 PM
  5. Basic Pool Cleaning -- What do I do?
    By subedoo in forum Pool Cleaning: Manual or Automatic
    Last Post: 08-02-2006, 01:33 AM
