1. Add 20 Mule Team borax, 2 boxes per 10K gallons, slowly to the skimmer with the pump on. Retest pH after 2 hours of circulation. Repeat every 4 hours till your pH is above the minimum level, then continue with 1 box per 10K gallons, till your pH has reached 7.4. Do NOT worry about alkalinity now.
2. Use this form to give us the info we need to make recommendations about YOUR pool:Pool Chart Entry Form3. Add 4 gallons of PLAIN 6% household bleach to your pool, per 10K gallons, and then BRUSH the pool completely, to make sure that the piles shown on the bottom in the first pic are dead.
Pool Chart Results
