Results 1 to 5 of 5
Thread: leaves
    Jun 2011
    Wisconsin
    Talking leaves
    Hi,
    Every year when I open the pool, despite my best efforts, and a leaf net which goes on in September, I end up with masses of leaves in the deeper sections of my pool. After being there all spring, they are slimey, smelly, and raise havoc with my chemicals in the Spring. Does anyone have a suggestion for a pool cleaner, or a great idea for getting the leaves out right away? I live in Wisconsin , so until the end of May, water temperature prohibits me from getting in to dig them out. I have a 20,ooo gallon 16x32 above ground pool which is submerged to 6 feet on 1 end. Any great ideas or suggestions would be so.....appreciated!
    16'x32' oval 20K gal AG pool; Liquid Bleach; Hayward pro series, 18 inch sand filter; Hayward Pro series 1.5 hp pump; 15 - 20hrs; Taylor, k2006; well; summer: ; winter: ; android phone; PF:6
    Default Re: leaves
    Hi Mrs. rainbow,
    I'm sorry that you haven't gotten any replies to this--I'm not sure how, but I missed it, too.....
    Do you have a leaf net? It fits on the end of your telescoping pole and looks a little like a butterfly net with a squeegee attached on one side. It allows you to scoop the leaves out of the pool without having to get in. I got mine at my local Mom n' Pop store, but I think WalMart and most chain stores sell them, too. I don't have any trees in my yard, but my neighbor has a literal forest--and in the winter, all her leaves blow over my fence and straight into the pool. I have a Polaris that is great with leaves, but doesn't run well in water below about 70 degrees, so for me the leaf net is a real lifesaver.
    Jun 2011
    Wisconsin
    Default Re: leaves
    Thanks Janet, I will check this out. I appreciate your help
    Apr 2012
    New York
    Default Re: leaves
    They also make "leaf vacs" that attach to the garden hose. They are not perfect, but they do work pretty well with some maneuvering.
    I bought one like this - -
    The water from your hose blows up into a net, which sucks the leaves in. We just had a huge storm and it worked perfectly for the big leaves, and even sticks and "acorn" type stuff.
    Jun 2011
    Wisconsin
    Default Re: leaves
    Thanks for the tip, I will check this out!
  1. Polaris and leaves
    By hooeld in forum Pool Cleaning: Manual or Automatic
    Last Post: 11-13-2006, 03:38 PM
  2. Leaves on bottom of pool
    By Pool_Mike in forum Pool Equipment & Operations
    Last Post: 11-05-2006, 02:29 AM
  3. Leaves and snow/ice
    By denanbob in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-25-2006, 11:35 AM
  4. Tons of leaves & other stuff
    By sartail in forum Pool Cleaning: Manual or Automatic
    Last Post: 07-03-2006, 07:29 AM
  5. leaves
    By rainhill in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 04-20-2006, 06:19 PM
