Thread: Muriatic Acid Vs. Sodium Bisulfate?
    Dec 2005
    Bakersfield, CA, USA.
    Default Muriatic Acid Vs. Sodium Bisulfate?
    Besides any cost differences, is there any difference in using these two methods of lowering Ph? I ask because I am new to this, having had a pool for only a week. After handling Muriatic a few times, and reading all the warnings about the stuff, I feel I might be more comfortable in the long run with dry acid. I see so many still use Muriatic, so I'm thinking it must have better properties or something?
    Katy, TX
    Default Re: Muriatic Acid Vs. Sodium Bisulfate?
    I like muriatic because it leaves no residue. With dry acid, you'll build up sulphates in the pool over time. Now I don't know how serious that is but it's easier for me to use muriatic. The only byproducts are water and salt.
    Michael
    Safety and ease of use vs. cost and sulfate buildup.
    I guess for occasional use, Dry Acid is probably better (I prefer it).
    But if I had a curing concrete pool, or an SWG constantly pushing pH up, I think I'd be using Muriatic Acid instead.
  1. Where to get 31.45% muriatic acid?
    By laughingboy in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-30-2010, 12:31 PM
  2. Asc. acid v. sodium bisulphate
    By Carolina in forum Dealing with Stains & Metals, . . . and 'Minerals' & 'Ions',
    Last Post: 08-06-2007, 05:16 PM
  3. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 01:54 AM
  4. How to add muriatic acid
    By BullDean in forum Pool Chemicals & Pool Water Problems
    Last Post: 06-12-2006, 11:51 PM
  5. how much muriatic acid
    By wolfcue in forum Dealing with Alkalinity and Calcium
    Last Post: 06-07-2006, 06:55 PM
