Thread: Skimmer installation question
    May 2012
    Bensalem, PA
    Default Skimmer installation question
    I recently replaced the skimmer on my 24' round above ground pool. I have 2 tiny pinhole leaks that are coming down the outside wall of the pool.
    The skimmer came with a butterfly gasket and I installed in the following order...
    Wall plate-->inner part of gasket-->liner-->pool wall-->outer part of gasket-->skimmer.
    I've read conflicting posts that the inner part of the gasket should go against the pool wall with the liner on top of it.
    Wall plate-->liner-->inner part of gasket-->pool wall-->outer part of gasket-->skimmer.
    Anyone know which installation is correct?
    Thanks!
    Default Re: Skimmer installation question
    Welcome to The Forum!
    The gaskets should be touching the wall with the liner touching the faceplate.
    As a practical matter, it probably doesn't matter, but since you have a leak, you might as well redo the installation.
  1. Pool Liner Installation Question
    By JJNMRSDAD in forum In-Ground Pool Construction and Repair
    Last Post: 07-29-2011, 08:34 PM
  2. Liner installation question
    By pfpool04 in forum Above-Ground Pool Construction & Repair
    Last Post: 08-19-2010, 08:16 PM
  3. Solar panel installation question
    By cleancloths in forum Pool Equipment & Operations
    Last Post: 05-09-2007, 04:44 PM
  4. Tile installation question
    By keithw in forum In-Ground Pool Construction and Repair
    Last Post: 07-07-2006, 12:16 PM
  5. Solar cover installation question
    By prh129 in forum Above-Ground Pool Construction & Repair
    Last Post: 05-09-2006, 06:29 PM
