Re: cloudy SWG pool opening...new to pools
The cloudiness is dead (bleached) algae. Try adding a layer (handfull or so) of D.E., or better one of the cellulose-fiber alternatives) through the skimmer to help the sand filter clear it faster. You want to see the tank pressure rise about 2# when you add the product.
For your SWG, add a sequestering agent designed for use with these to the pool. If one spwcifically designed for SWG use is not easily available, you should still keep a good sequestering agent in the pool, generally added once a year. They help keep the cell cleaner. Get your pH (and probably alkalinity) up or you will be replacing a very expensive cell and other parts of your equipment sooner than you should.
Try this link: http://www.jacksmagic.com/page.cfm?id=372
