Thanks for the suggestion. I will try it and see what happens.
Susan,
Running your filter and some vacuuming to clean your pool and using bleach for chlorination should keep your pool sparkling all Summer. Up your run time on your filter and keep a closer eye on managing your water (posting a set of test results would be VERY helpful) rather than chasing your issue with other additives.
You are consuming a little extra bleach. (possibly from organics or just the sun....can't tell without test results) Try bringing your CYA to 30-40 and adding your bleach in the evening when practical....you'll get better efficiency.
here are my most current readings:
cya: just under the 30 mark
chlorine: 6
ph: 7.2
alk: 140
i added clarifier to the water a few nights ago. the brown stuff on the bottom seemed to get larger in size. i put the filter to waste and tried to vacuum it all up. I also put a sock on the skimmer basket. This morning there were still some brown spots on the bottom, just like dust when i go over it. i am wondering if when i am vacuuming it is stirring it up into the water? and then settling back down when i am done. I filter the pool 24 hours a day. Should i normally be doing less? The water is very clear, just the spots on the bottom now.
thanks again for your time/suggestions!
Just a quick update for anyone else who has seen this problem-
My pool looks great!! I vacuumed a day or two after adding the clarifyer and put it to waste. It has not come back since!! Thank you for helping!
I went through this same thing over the weekend.
Thought it was algae that kept growing in the same spots
Turns out I have a lot of small divots in the liner, on the bottom of the pool. I am thinking they formed over the winter.
Dirt was collecting in them as the water circulated around. With a little more dirt being added each day, it looked like algae growth
Finally just kept vacuuming this past weekend until I got rid of it.
I get the same thing, especially when no one is in the pool. I've come to realize it is dirt when my yard or the neighbors yard is being mowed or when it is real windy I get a lot of debris that settles in the divots of the liner. As long as they don't "multiply" I can live with itOriginally Posted by haze_1956
They vacuum or stir right up.
this is good to know. I keep getting a line right where the shallow end starts sloping towards the deep end. I just put in the aquabot and it sucks it up.
- betty
