Thread: Oval construction - straps and uprights uneven
    Default Re: Oval construction - straps and uprights uneven
    Hi, if it were me I would drill some new holes and set the braces in line. I use a string line to make sure all the braces line up on both sides. It is important.
    You could also add an extention to the strap by finding a similar material, cutting the strap and bolting the new piece into place.
    I would do something, Dennis
    Thanks - I kind of suspected thats what we should do. The pool came with some shorter straps to be used with the buttress brace model - we were instructed to discard them but we save everything. We will look at drilling new holes but if that won't work, those extra straps will be used for cutting to make an insert/extension. It ends up being a total of about 1.5" short between the sides, we leveled, measured, more leveling, measuring - still short. This should solve the problem nicely.
    thanks Dennis
  1. AG pool water level uneven? Help needed ASAP.
    By mjs31 in forum Above-Ground Pool Construction & Repair
    Last Post: 06-14-2007, 08:34 AM
  2. Uneven water level
    By Ken S in forum Above-Ground Pool Construction & Repair
    Last Post: 07-29-2006, 10:50 PM
  3. uprights
    By mets2006 in forum Above-Ground Pool Construction & Repair
    Last Post: 07-20-2006, 07:14 PM
  4. Straps Under Line
    By kanane in forum Above-Ground Pool Construction & Repair
    Last Post: 06-23-2006, 09:57 PM
  5. Replacement Solar Reel Straps
    By PhantomAndy in forum In-Ground Pool Construction and Repair
    Last Post: 05-25-2006, 11:50 AM
