Sounds like a recipe for disaster -- one I've seen many times. Dealing with chlorinated pools indoors is hard; dealing with chlorinated (or brominated) spas indoors is much harder.
Lemme show you some pictures. First, here's the pool, the other pictures are associated with -- because it wasn't heated or aerated regularly it was NOT nearly the problem your Endless Pool will be:
And, here some of the consequences:
Now, I didn't know as much then (2000 -- my first digital camera) as I do now. I took a picture of the electrical panel, for reference,
but if I had, this is what I would have found (pic from Nachi.org -- National Assoc. of Cert. Home Inspectors):
Notice how the green copper chloride goes all the way into the wiring connection points. Copper chloride is NOT a good conductor. Having bad conducting surfaces on electrical wires causes resistance. Resistance causes heat. And, hot wires start fires!
I know of multiple cases of building destruction by badly managed indoor pools (and almost all are badly managed!)
Here's the good news:
1. The problem can be solved.
2. I can help.
But, there's more bad news.
1. The fix is NOT easy.
2. Or cheap.
3. I won't help for free.
4. Or, now -- you'd have to wait till this fall.
5. Hardly anybody -- including pool engineers -- knows how to do this right.
If you want to fix this yourself, do all these things:
1. Remove 100% of the existing wiring, lighting, and sheet rock in the room.
2. Rewire ONLY what's essential, using full plastic conduit, outdoor receptacles, switches, and fixtures.
3. Wiring must be SOLID wire only, and a full ground must be run everywhere.
4. Install a corrosion resistant air-to-air heat exchanger, and set it to run continuously, venting the room and replacing room air with fresh air.
5. Have the ventilation installer balance the air flow, so the room with the spa is at NEGATIVE pressure, relative to the house, or any other connected building.
6. Install water-resistant and mildew resistant sheet rock.
7. Contract for ANNUAL inspections of the switches, wiring and receptacles, and the air balance, to assure that corrosion is NOT occurring, and that negative air pressure is maintained 100% of the time.
8. If you install a dehumidifier, replace it annually OR have it inspected for corrosion.
9. Install a smoke detectors, but replace THEM annually, to avoid corrosion induced silent failure.
10. Consider the use of an EFFECTIVE non-chlorine sanitation system, such as high output UV + DE filtration + dosing with peroxide to 50 - 100 ppm and polyquat to 2 - 4 ppm. Note that this will maintain water clarity, but is NOT sufficient to allow you to safely swim with anyone who is carrying giardia, crypto, or any other bacterial, viral or amoebic GI infection, a bad cold, herpes, or some other things.
A BETTER ALTERNATIVE:
1. Put the pool in an covered but OPEN garage.
There. You just got $5,000 worth of design advice that you probably could not get anywhere else in the world. I know you probably think I'm going overboard. I wish I had photos of all the disasters I've seen -- including one event in which a feed system design error error on a NEW indoor pool did $200,000 worth of damage in ONE weekend. (I was a paid consultant on that one; the mechanical engineers ended up hating my guts, and demanded that all photos be turned over. Because it was a showcase project at a non-profit for them, with donated fees, they got what they wanted.)
Sorry.
