Thread: White Cloudy water
    Default Re: White Cloudy water
    We need to have test results, taken with a drop-based kit to be able to tell you anything useful--without them, we'd just be guessing. What type of pool (liner, fiberglass, etc), what exact chemicals (ingredients, not just "shock") have you put into the pool, and what are your current readings for Cl, pH, alk, CH, and CYA?
    You need to avoid adding anything the pool store tells you to add EXCEPT what's needed to maintain chlorine levels OR to keep the pH above 7 or below 8.
    And you need to learn to test your water accurately. A few pool stores have reliable testing, but most don't. The only way to you ca tell the difference, is to test your pool accurately yourself . . . but once you can do that, you don't need the pool store!
    Test kit info page linked in Janet's sig (above).
