Results 1 to 10 of 10
Thread: Starting with SWCG - no chlorine level
    Jun 2012
    Upstate NY
    Default Starting with SWCG - no chlorine level
    Hello. We have a 22X52 round pool by Intex. We have a 2,500 gph filter and have started using the Intex SWG. The only way we could get water into the pool was to pump from our pond. We have been running the filter and using the SWG approx. six hours a day. We have tested the salt level and it is good. The test strips we have say that there is no chlorine present. We have not added cyanuric acid. Could this be why the pool is still looking like pond water? It's still green/brown. It's supposed to be a warm weekend here and we would like the kids to be able to swim in it. Any help would be appreciated!!! Thank you.
    Default Re: Starting with SWCG - no chlorine level
    Hi brefri;
    Do this:
    1. Enter your pool info:
    Pool Chart Entry Form
    Pool Chart Results
    2. Get a cheap OTO (yellow drops) test kit (see test kit info page in my sig) . If possible, get an HTH 6-way drops kit from your local Walmart. Some have them; some don't. Order a K2006 *and* salt test strips.
    3. Do NOT count on your SWCG for cleanup. SWCGs work for routine chlorination; not for clean up . . . and that's a SMALL SWCG.
    4. Begin treating your 11,000 gal pool (PF=11) with 4 gallons of PLAIN 6% household beach each EVENING. Repeat the dose each following evening, if the OTO kit does not show dark yellow.
    5. If you have the cartridge filter, get (2) Unicel replacement cartridges. These will filter the algae (once it's dead) better than your existing cartridges, and will last all summer if you rotate and clean them properly. Do not try to buy them locally since what's usually sold are other Asian source replacements that are NOT equal in quality.
    Unicel C-4607 Replacement Filter Cartridge (Easy Set Size A or C) @ Amazon
    Unicel C-5315 Replacement Filter Cartridge for 15 Square Foot Intex B Filter @ Amazon
    For cleaning -- but you can buy these locally:
    Rubbermaid BRUTE Gray 10 Gal Container w/o Lid @ Amazon
    Round Brute Lid For 10-Gallon Waste Containers, 16" Diameter, Gray
    1lb Savogran 10621 Trisodium Phosphate (TSP) @ Amazon
    6. Read the muriatic acid page in my signature; use either muriatic acid (to lower) or 20 Mule Team borax (to raise) to make sure the pH is above 7.0 and below 8.0
    7. Once you have an HTH 6-way or the Taylor 2006, report full test results. Do NOT waste the CYA test, if you have not added CYA, nor the salt strips, if you have not added salt.
    Jun 2012
    Upstate NY
    Thank you for your quick and detailed response. It is very appreciated! We added 4 lbs. HTH 3 in 1 pool startup for salt pools which contained cyanuric acid, vacuumed the pool, then added almost four gallons of Clorox last night and ran the filter all night. This morning, the pool is still green/brown (looks like the pond). I tested this morning using the HTH 6-way test strips. The results:
    Free Chlorine/Bromine = 5/10
    pH= 7.2
    Alkaline = 40
    Cyanuric Acid = 0
    I've modified my goal of being able to swim in it today. Now I'm hoping for tomorrow? I may drive to Wal-Mart right now and buy some algaecide and try that today??? I really don't know what else to do.
    Thank you!
    • Do NOT use algaecide, especially from Walmart. It will make things worse, not better. Even polyquat -- which we sometimes recommend -- would NOT speed this up.
    • Use borax -- 20 Mule Team borax -- to raise your pH to around 7.6. Add 1/2 box at a time -- slowly, to the skimmer, pump on -- wait 4 hours, and retest.
    • Buy 10 gallons of PLAIN 6% (check the %) household bleach. Add 2 gallons immediately, and 2 more tonight.
    • Buy a cheap OTO (yellow drops) test kit. If you go to Walmart, they may have the HTH 6-way DROPS kit -- it's an excellent starter kit. Get if if you can. 'Guess-strips' are NOT an acceptable substitute.
    I may be too late, but I wouldn't add algaecide. Algaecides are a pretty good preventative but not so great at killing algae, plus most of them cause other problems like foamy water. So, if you haven't already added some, I would advise against it. By the way, you do not have bromine in your pool. You can ignore that side of your tester.
    Jun 2012
    Upstate NY
    Thank you. You caught me before I went to Wal-Mart - it is a distance from my home so I hadn't left yet. I appreciate it. I will do everything you suggested this afternoon. It has caused quite a discussion in the house - algaecide or no algaecide!
    Chlorine is -- by FAR -- the strongest available algaecide.
  1. Unable to keep chlorine level and CYA level has dropped from 38 to 21 in 1 day.
    By lizbyrne2000 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-22-2013, 12:41 PM
  2. CYA level and chlorine level and pool store recomendation
    By Fishcrazy in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 08-21-2011, 11:25 AM
  3. Will high chlorine level harm my new SWCG?
    By Furbabyvet in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 05-02-2011, 06:56 PM
  4. Determing water level in ground before starting
    By tybeeware in forum In-Ground Pool Construction and Repair
    Last Post: 05-19-2006, 01:06 PM
