Help
Remember Me?
Forum
FAQ
Calendar
Forum Actions
Mark Forums Read
Quick Links
View Forum Leaders
What's New?
Advanced Search
Forum
Starting with SWCG - no chlorine level
FAQ
register
Results 1 to 10 of 10
Thread:
Thread Tools
Show Printable Version
Email this Page…
Subscribe to this Thread…
Display
Switch to Linear Mode
Switch to Hybrid Mode
Threaded Mode
Threaded View
06-09-2012
02:37 PM
#7
PoolDoc
View Profile
View Forum Posts
Administrator
Quark Inspector
Re: Starting with SWCG - no chlorine level
Chlorine is -- by FAR -- the strongest available algaecide.
Quick Navigation
Top
Site Areas
Settings
Private Messages
Subscriptions
Who's Online
Search Forums
Forums Home
Forums
Ben's Corner
Forum Q & A
-- Subscriber Posts --
Dealing with Algae & Slime
DPD-FAS based testing
Pool Equipment & Operations
Pool Electronics
Odds-n-Ends (P)
Photo Gallery
Clearance
--cleanup--
The China Shop
General Interest
Practice Forum
PoolSolution Archive
The Hall of Shame
New Intex 16' x 48" pool owner
BBB and SWCG at setup Summer Escapes pool
Unable to keep chlorine level and CYA level has dropped from 38 to 21 in 1 day.
By lizbyrne2000 in forum Testing and Adjusting Pool Water Chemistry
7
Last Post:
06-22-2013,
12:41 PM
CYA level and chlorine level and pool store recomendation
By Fishcrazy in forum Using Chlorine and Chlorinating Chemicals
31
Last Post:
08-21-2011,
11:25 AM
Will high chlorine level harm my new SWCG?
By Furbabyvet in forum Salt Generators (SWCG) & other Chlorine Feeders
3
Last Post:
05-02-2011,
06:56 PM
Determing water level in ground before starting
By tybeeware in forum In-Ground Pool Construction and Repair
3
Last Post:
05-19-2006,
01:06 PM
Digg
del.icio.us
StumbleUpon
Google
You
may not
post new threads
You
may not
post replies
You
may not
post attachments
You
may not
edit your posts
BB code
is
On
Smilies
are
On
[IMG]
code is
On
HTML code is
Off
