Closed Thread
Thread: The BBB Method...B-B-B...What is THAT????
    Exclamation The BBB Method...B-B-B...What is THAT????
    They stand for the supermarket chemicals:
    Bleach for chlorine--regular or ultra unscented. 1 gallon of regular bleach, with a 5.25% concentration will add 5.25ppm of Free Chlorine (the good stuff--FC) to 10,000 gallons of water. 1 gallon of Ultra at 6% will add 6ppm of FC to 10,000 gallons of water.
    Borax for raising pH--"20 Mule Team Borax" at the supermarket, and
    Baking Soda for raising Total Alkalinity. Good Ol' Arm & Hammer--or generic.
    We also generally use Muriatic Acid to lower pH--this is available at hardware and tile stores. But Dry Acid is OK to use as well.
    From the Pool Store, you need only CYA/Stabilizer/Cyanuric Acid (all the same thing) and if you MUST have an algaecide, use Polyquat 60%... it's not a brand, you look at the label and if it says "Poly [oxyethylene (dimethyliminio) ethylene (dimethyliminio) ethylene dichloride]" and nothing else, or "inert ingredients" that's the stuff. It can be called Algaecide, Black Algaecide, Mustard Out, etc....check the label and go by that.
    Default Re: The BBB Method...B-B-B...What is THAT????
    I've removed all the other posts attached to this sticky--and incorporated relevant info into the main one.
Closed Thread
  1. What's the BBB method?
    By PoolDoc in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 03-25-2011, 10:16 PM
  2. New to BBB Method ... 100 CYA
    By tabjraxa in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-05-2009, 11:47 PM
  3. BBB Method - what is it??
    By lovedisney in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-01-2007, 11:21 AM
  4. The B method.....
    By matt4x4 in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2006, 12:34 PM
