Results 1 to 4 of 4
Thread: Phosphoric acid & pH
    cygnusecks is offline Unconfirmed User Thread Analyst cygnusecks 0
    Orlando, FL
    Default Phosphoric acid & pH
    All,
    I am preparing to seal my paver deck around the pool. Yesterday I applied a solution of "Behr Concrete Etcher & Rust Remover No. 991" to my deck to clean it/dissolve efflorescence and during rinsing a good deal of it was rinsed into the pool. It took 1.75 gallons of the product to finish the job, and I figured it would lower my pH since I would guestimate maybe a 3/4 gallon probably ended up in the pool. Pool is 14k gal inground pebbletec/gunite pool.
    After a few hours or cleaning up and running filter, pH tested normal at 7.6 (i.e. no change). I was a little surprised. My Alk level is 100. Does this sound unreasonable that the pH wouldn't change after 3/4 gal of phosphoric acid was dumped into the pool?
    The MSDS for this stuff is at
    http://www.msdsvault.com/msds_custom...hreg954&ab=991
    It is 30-60% Phosphoric acid.
    waterbear's Avatar
    St. Augustine, Fl
    Default Re: Phosphoric acid & pH
    Phosporic acid is a mild acid but the main reason that is probably didn't affect your pH is that is was neutralized by the calcium carbonate 'efflouressence' that it dissolved which is mildly alkaline. Therefore the water that washed into the pool probably had some calcium and some phosphates in it but was near a neutral pH.
    Orlando, FL
    Ah, cool, makes perfect sense waterbear. Great, just what my 500ppm CH-level pool needs -- more calcium!! :-) Soon as I get an accurate read on CH using my PS234 which is theoretically on order, I'm gonna fix the CH level and bring it down some. I'm not sure it's great for the gas heater!
    waterbear's Avatar
    St. Augustine, Fl
    Depends on what you TA is at. If it's at the low end of the recommended range and the CH not above 500 ppm AND you have no visible scaling happening then you might be ok.
  1. Where to buy CYA? & acid ?
    By PJM361 in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 01:13 AM
  2. Dry acid vs Muratic acid
    By jackinlv in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-25-2011, 01:44 PM
  3. Lowering TA with Dry Acid Or Muriatic Acid
    By CelticDaddio in forum Dealing with Alkalinity and Calcium
    Last Post: 07-05-2007, 01:54 AM
  4. Too much acid?
    By k2vell in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-07-2006, 10:57 PM
  5. Dry acid versus muratic acid - and how to add?
    By west1745 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-03-2006, 01:19 AM
