Thread: Pump noise after seal change
    Jun 2012
    Pennsylvania
    Default Pump noise after seal change
    I just changed the seal in a Hayward 1 hp pump and now the pump I running a little noisy. No leaks and pressure is fine. Any ideas out there as to what may cause this before I tear it apart?
    Default Re: Pump noise after seal change
    Welcome to The Forum!
    My first thought is that the impeller might not be fully tight. The other thing that jumps to mind is that a pebble, or something, might have gotten into the housing when you did the change out.
    Jun 2012
    Pennsylvania
    Quote Originally Posted by waste View Post
    I checked out the pebble situation in the housing and found a lot of DE(I was putting DE in when all this was happening) I cleaned all up and tried again to find the noise still there. Now I'm beginning to think DE has gotten into a motor bearing. Is it worth replacing a motor bearing or will the DE eventually go away?
    Ed
