Thread: Spill Over Spa Cover
    Default Re: Spill Over Spa Cover
    I use a floating solar blanket on my spillover spa that I cut to fit and left a flap over the spillway. It works great at keeping in the heat and keeping stuff out (if you remove it carefully)! I don't drain my spa because it get used all the time! The blanket is much easier to put on and remove than a hard spa cover. Might be an option if you care to leave your spa filled.
    Michigan
    Do you have a cover on your pool ? Any issue with it blowing off ?
    Cover on the pool is also a floating solar blanket. Since my pool is an odd shape I do not have a reel and have to put it on and take it off manually (which is actually pretty easy to do). I did have a bit of a problem with it blowing off at first until I made sure it was trimmed to be slightly smaller than the pool and was completely floating. Now the surface tension of the water seems to hold it in place nicely. Actually, I have not used the cover on the pool since the weather got warm and just keep the one on the spa to help keep the heat in. The downside is that there is always pollen and stuff floating on the pool now that I have to skim out. With no cover on the pool and the cover on the spa I can even turn the spillover on with no problems...the spa cover just floats up a bit higher and the spillover works perfectly.
  1. Intex debris cover or solar cover
    By Larryh86GT in forum Pool Equipment & Operations
    Last Post: 06-12-2013, 06:06 PM
  2. Water rolls over spill way when in spa mode
    By tankcj in forum Pool Equipment & Operations
    Last Post: 04-17-2013, 08:55 PM
  3. Solar Cover as Winter Cover?
    By CoffeeBean in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-02-2007, 11:46 AM
  4. Airate with Spill over Spa
    By aswetich in forum Dealing with Alkalinity and Calcium
    Last Post: 09-06-2006, 09:28 AM
