Results 1 to 10 of 17
Thread: Walmart chlorine vs Chlorinator
    Jun 2012
    Pittsburgh
    Default Re: Walmart chlorine vs Chlorinator
    okay got my new test kit the k-2006 here are my readings I think (not good at science) I need to add 4lbs of Borax and some chlorine just not sure how much maybe 3 gallons again
    FC=1.4
    CC=1.0
    PH-7
    Alkalinity =100
    Calcium Hardness - 230
    CYA = 60
    20'x40' rectangle 30K gal IG vinyl pool; skimmer tabs and trichlor feeder; hayward DE filter; pump; 24hrs; ordered k-2006 not recevied yet. aquacheck pool kit is what I currently have; utility water; summer: solar; winter: mesh; ; PF:4
    With a CYA of 60, you need to keep your chlorine in the 5-10 ppm range all the time, otherwise you're going to end up with a green pool. With your chlorine being low, and your CC already at 1.0, I would go ahead and shock the pool, which is going to mean raising your chlorine to 20 ppm to get rid of whatever's trying to grow in there. As Pooldoc pointed out, each gallon of bleach will raise your chlorine by 2 ppm, so you need to add more like 10 gallons in order to achieve shock level for your CYA.
    How does your water look?
    Jun 2012
    Pittsburgh
    If the Chlorine is in the 5-10 or 20 range is it safe to swim? Water is clear as day it looks great. I tested tonight before I put anything in and FC was 3.2 so it is holding the chlorine better already but CC is still 1.0 Ph was around 7.3 it was between the 7.2 and 7.4. I put 4lbs of borax and 1 gallon of chlorine because I wanted to wait to see about the swimmability before I went and dumped all that chlorine in. Thanks everyone
    Quote Originally Posted by superburg View Post
    Perfectly safe. And, with a CYA of 60, it's not even likely to fade your swimsuit (@ FC=20)
