Results 1 to 10 of 76
Thread: fighting mustard algae
    Kateyru is offline Subscriber Thread Analyst Kateyru 0
    Apr 2012
    Alabama
    Default Re: fighting mustard algae
    I added muriatic acid when I was at home for lunch. Will re-check pH this afternoon and get it down < 7.8 then test TA. I'm continuing to shock at mustard algae level. Pool water seems to have gotten way out of whack...
    thanks much!
    16'x30' rectangle 22K gal IG vinyl pool; SWCG; Hayward Pro SEries S220T sand filter; Hayward pump; hrs; Taylor K-2006 ; city; PF:5.5
    Did you sign up for the Pool Log? (I haven't matched email addresses with user names yet -- we'll do that in the next few days, and set up all the forms and spreadsheets.)
    If not, you need to do so. (Did you get an email about it?)
    Apr 2012
    Alabama
    Is the Log the same as Pool Chart Entry and Results forms or Pool History entry or logsheet? If so, those were set up and have some info. I will update if that's where my info needs to be. I have not received an email about the log.
    thanks.
    Apr 2012
    Alabama
    Help!!!!!!! I added 20 oz acid at 12:30 today to lower ph. Tested again at 5 and added another 6 oz. Per Pool Calculator, this should get my pH to 7.6. I was heading to store for more bleach (for mustard algae shock) and decided to test TA so I could pick up some baking soda too. I thought my TA was 48 on 7/31. I just tested (6pm) and TA is basically off the chart on the high side. I used K-2006 kit and tried using the regular test of filling tube to 25 ml. I quickly realized that I was putting in too many drops trying to turn water red so started off and used 10 ml sample. I quit after adding 22 drops of R-0009 and still hadn't turned sample red...it was green, then blue, then yellow and heading darker/to red but, YIKES, that is some high TA.
    Do I lower pH to 7.2 and aerate pH to 7.6 then lower again???????
    Quote Originally Posted by Kateyru View Post
    Watch this video, and retest: http://www.youtube.com/watch?v=gmpS-...ature=youtu.be
    The rest of the videos are here: http://www.poolforum.com/pf2/showthread.php?17157
    Apr 2012
    Alabama
    THANKS!!!! That was really weirding me out!!!
    Apr 2012
    Alabama
    Hi Team,
    An update and questions...test results from earlier this morning are:
    pH = 7.2
    TA = 90
    CYA = 35
    FC has been drifting down since mustard algae shock attack. My estimate of FC is 15. I had to use dilution test as I am out of reagent to use with K-2206 test.
    Questions:
    1) is there a way/procedure to use fewer drops of R-0871 when repeatedly testing FC at mustard algae shock levels?
    2) should I continue to lower TA (by adding acid to lower pH then aerating then repeating)
    3) When should I add CYA to raise it? I've added several times this summer and am surprised it is as low as 35 but I triple- checked it today
    I'm hoping that I have successfully removed the mustard algae but time will tell. No more extended trips away from home/pool should help.
    thanks for your continued assistance!
