Results 1 to 3 of 3
Thread: Gonna ask
    Kannapolis, North Carolina
    Default Gonna ask
    Well day one of my pool opening and I shocked the pool, after doing so I turned the valve to recirculate and lost a lot of water but, my question is this when I returned the valve to filter I didn't loose anymore water, so WHERE am I losing the water at?
    Orlando, Florida, USA.
    Default Re: Gonna ask
    Recirculate just means the water is by-passing the filter.
    How much water are you losing?
    Is it possible that you put the filter in backwash position? Even then it should be obvious where the water is going unless you had a direct connection from the backwash outlet to a sewer line.
    I guess it is possible I had it in between the 2 but I didn't even look to see if it was coming out of the waste pipe, I wish I were plumbed into the sewer pipe.
