Thread: Newbie with intex pool. Solar arc
    Jun 2012
    Connecticut
    Default Newbie with intex pool. Solar arc
    Hi we are in connecticut. We have a 24' x52" intex pool with salt water and the crystal clear intex pump. The pool is not in the sun all day. We have been wanting a solar panel to heat it up a bit even though our neighbor who is a pool fanatic said we don't have a way tO use one with no south facing areas near our pool. But I have read and heard from others that as long as you have 4-6 hrs of sunlight on a panel it wi heat it at least 5-10degrees.
    I saw an ad for the Solar Arc that fits intex pools. I am trying to find anyone who has a review or opinion on it. I cannot use the search feature in the forum. Hopefully you can assist me with Using this feature.
    Stephanie
    Default Re: Newbie with intex pool. Solar arc
    You can use the google search feature linked in my sig, but you may have to log out to read the results untilBen upgrades your registration. The google search feature works much better than the v. bulletin search feature anyway
    membership upgraded - ben
  1. intex pool to solar heater valve
    By stneasy in forum Above-Ground Pool Construction & Repair
    Last Post: 05-19-2013, 01:21 AM
  2. Newbie here! Already filled my intex 15x36 pool with water (Oops!)
    By joolz1226 in forum Pool Chemistry for Intex-type Pools
    Last Post: 08-03-2012, 08:40 PM
  3. Newbie with New 15'x48" Intex Pool
    By dandelion in forum Pool Chemistry for Intex-type Pools
    Last Post: 07-13-2012, 09:03 PM
  4. Another newbie with an intex......
    By amyinraleigh in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 07-29-2006, 09:44 AM
  5. Solar panel with a Intex frame pool?
    By Kimrst in forum Above-Ground Pool Construction & Repair
    Last Post: 05-28-2006, 07:49 PM
