Thread: Ph High
    sisie5 is offline Registered+ Thread Analyst sisie5 0
    franklin, in, us.
    Default Ph High
    Need help my Ph is 8.2 and my cl is 3 question do I adjust the ph first and then cl.also can I use Ph minus instead of acid
    thanks
    Default Re: Ph High
    Yes, you can use pH minus instead of acid, and it really doesn't matter which you adjust first, Cl or pH.
