Thread: Ph High
    sisie5 is offline Registered+ Thread Analyst sisie5 0
    franklin, in, us.
    Default Ph High
    Need help my Ph is 8.2 and my cl is 3 question do I adjust the ph first and then cl.also can I use Ph minus instead of acid
    thanks
    Default Re: Ph High
    Yes, you can use pH minus instead of acid, and it really doesn't matter which you adjust first, Cl or pH.
  1. Advice Needed - High CYA, High Nitrates, and Lots of Algae
    By capshockeyfan in forum Pool Chemicals & Pool Water Problems
    Last Post: 07-03-2012, 05:47 PM
  2. High amounts of DPD Powder needed!! To high or no Clorine?
    By KaseyNewman in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 01-16-2012, 11:52 PM
  3. High Phosphates > 1,000 & High Nitrates 90ppm
    By applepar in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-23-2011, 05:49 PM
  4. had algae, PH high, TA high, water now cloudy
    By Mom4fun in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 06-12-2011, 01:09 PM
