Thread: hayward super pump
    Jun 2012
    Indiana
    Question hayward super pump
    When turning on my hayward super pump 1 hp, motor will humm for about 10 sec then shut off. When i felt the motor it was hot so i'm assuming that it is overheating. What would cause the overheating? Any "home remedies" before i spend money on a new motor?
    Thanks!
    Default Re: hayward super pump
    The equipment guys will be able to offer better opinions, but having had this happen before on my pump, my first action would be to take it apart and see if there's something stuck in the impeller, causing it not to be able to turn. If the impeller is clogged, clear it out and that may solve your problem. If the impeller is not clogged, see if you can get it to turn by hand. If it won't turn by hand, one possibility is rusted bearings. This will happen if you develop a leak at the shaft seal and don't replace the seal. If this is the case, sometimes you can work it a little and get it to turn again, but be prepared for a very noisy pump once you start it back up.
    Janet covered some of the basics, even though she's not an "equipment person".
    Janet! Our newest equipment guru! Good job, girl!
  1. Hayward super pump 3/4 ?s
    By Messina1974 in forum Pool Equipment & Operations
    Last Post: 06-27-2013, 10:34 AM
  2. Hayward Super Pump is Super Noisy
    By moneypitpool in forum In-Ground Pool Construction and Repair
    Last Post: 07-25-2011, 10:16 AM
  3. Hayward Super Pump - Super Hot and Shutting Off
    By CapitalBoo in forum Pool Equipment & Operations
    Last Post: 06-18-2011, 09:32 AM
  4. Hayward Super Pump Really Hot...HELP?
    By calamtykel in forum Pool Equipment & Operations
    Last Post: 06-14-2009, 04:30 PM
