UGH! Variable speed? Which one?
Do I go with
Pentair?
Jandy?
Hayward? UGH!
Re: UGH! Variable speed? Which one?
Do have specific models that you're looking at, or are you needing opinions on brand names? There are some equipment guys on this forum that can help, but if you're needing info on specific models, they're going to need to know your pool volume, size/type of filter, any water features, and which models you're considering. If you're just wanting opinions on brand names, I'm sure they can give you that, too.l...
BTW, I deleted your other, duplicate post. When new folks post, it goes into a queue to be modded in, so that's why it didn't show up immediately.
I think I just need opinions on the brand names. I am looking at the Pentair VF
http://www.poolsupplyworld.com/pools...roducts/011012.
Ah, you posted this while I was editing my post above. Please reread it, because there's some additional info the guys are gonna need to be able to answer your question.
Pool: 23,000 gallons
Filter: 200 sq ft Sta Rite Cartridge
Heater: Sta-Rite Max-E-Therm Low NOx 400,000 BTU Natural Gas
I have a rock water fall, but that's connected to another pump.
My spa is connected to the pool
Any of the VS pumps will work with your setup but the VF is about $300 more than the VS with little benefit unless you really have to have the variable flow feature.
But probably the most important factor is if you have a controller and which pump it will interface with.
If you don't have a controller, probably the best is the Intelliflo VS 011018 which sells for around $900 and has a built in timer.
But with spa, maybe you want the SVRS feature? All manufactures have a version with that.
