Results 1 to 9 of 9
Thread: Salt Level not showing actual values
    Jun 2012
    United States
    Default Salt Level not showing actual values
    I have an aqua rite salt generation system in my pool. The digital display is reading 2100 for salt in the water and when I add salt the reading does not increase significantly. It was 1800; I added 60 lbs. of salt to get to 2100. The pool store says I am at 4900 and I have no salt based chlorine in the pool. Can you give me some advice for directions to troubleshoot?
    Read the display - 1800 initially
    Added salt - went to 2100
    Tool pool water to store for testing - 4900 at store
    Cell looks clean and not caked up.
    Adding Chlorine to control pool water until issue resolved.
    Default Re: Salt Level not showing actual values
    How old is your cell? Have you acid washed it recently?
    Jun 2012
    United States
    The total age on the cell is about 5 years. I have acid washed it about 8-10 months ago.
    I would try acid washing it again. If that does not work then it is most probably time for a new cell. Also if you would please complete the Pool Chart form. This allows us to quickly see what kind of pool you have . If a portion of the form doesn't apply to you, skip it.
    Pool Chart Entry Form
    Pool Chart Results
    Lexington, SC
    I have been having the same problem. I have an Aquarite Goldline generator. I replaced the cell about a year ago. It was working fine until lately it showed low salt levels at about 1800. My local pool store checked the salt and it read 4000! There is no chlorine being generated. I inspected the cell and cleaned it with a muriatic acid solution. It still reads low salt. Could it be something else like the flow sensor?
    mas985's Avatar
    Pleasanton, CA
    Probably not. A flow censor problem would alarm as no flow. The low salt readout is usually due to a failing cell or a calcified cell.
    Mark
    Lexington, SC
    Well I bit the bullet and ordered a replacement cell today. I was hoping for a less expensive fix. Thanks for the advice.
    mas985's Avatar
    Pleasanton, CA
    Are you sure you cleaned the cell well? A cell should last much longer than a year.
    Mark
    Virginia
    Quote Originally Posted by BogeyGolfer View Post
    Quote Originally Posted by mas985 View Post
    Unless it was one of those new "economy" cells only designed for one year, it should be under warranty.
  1. Salt Level Keeps High without Addition of Any Salt
    By TooSalty in forum The China Shop
    Last Post: 08-13-2011, 01:56 PM
  2. Recommended values for a SWG pool
    By Charlie in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-24-2011, 08:25 PM
  3. Salt level?
    By court475 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-11-2009, 01:11 AM
  4. my salt level
    By Bowlin in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-10-2006, 02:44 PM
