Results 1 to 8 of 8
Thread: Need to start BBB
    Jun 2012
    South Carolina USA
    Default Need to start BBB
    I need to be rid of the local pool store. Too many recommendations to spend money with no good results.
    Pool: 35,000g Gunite
    Current levels:
    FC .5
    TAC 1
    Bromine N/A
    ph 7.2
    TA 90
    Adjusted Alkalinity 60
    CYA 100
    CH 240
    TDS 800
    Phosphates 100
    Nitrates 5 ppm
    Getting a Taylor test kit tonight and need some help maintaining my pool............with your help of course. Thanks in advance. Dennis
    mas985's Avatar
    Pleasanton, CA
    Default Re: Need to start BBB
    Your chlorine level is too low for a CYA of 100. You need to adjust the FC level according to Ben's best guess chart:
    http://www.poolsolutions.com/gd/best...ine-chart.html
    or around 10 ppm FC.
    This will help to reduce the combined chlorine. But long term, it would probably be beneficial to lower the CYA.
    Mark
    BigDave's Avatar
    Jul 2010
    New Jersey
    Quote Originally Posted by dennistoner View Post
    FC .5
    TAC 1
    CYA 100
    You've got trouble brewin'
    You need alot more chlorine for that CYA level (which actually may be much higher). At least 8ppm FC according to Ben's Best Guess Chart.
    How does your water look?
    Do you have metals in the water?
    If your water has no metals and is clear, you'll need about 4-1/2 gallons of 6% bleach to get to the minimum 8ppm FC for CYA of 100ppm.
    If your water has no metals and is green, you'll need 14-15 gallons of 6% to reach your shock level of 25ppm FC.
    These amounts are only to get you to your required levels, you'll need more for maintenance.
    Alot of people on this forum find a good deal on bleach at wall mart. If the store in your area has the HTH 6-way kit, buy one. (Check availability) If not, pick up a cheap OTO / Phenol Red test kit.
    If you have metals, check back and let us know.
    Getting a Taylor test kit tonight...
    You do mean ordering a K-2006? With High CYA, the FAS-DPD test is essential for taking care of your pool.
    Jun 2012
    New Jersey
    Would it be good to also add a box of borax to raise the pH a few ticks? Or not worth it until the clorine is up?
    Hi juice;
    His current levels won't hurt anything; we tend to focus on the serious issues and then see if the minor ones are still around after the major ones have been fixed.
    Jun 2012
    South Carolina USA
    Yes, ordered the K 2006. The water is clear to see the deep drain (6' depth). My plan is to run my own set of tests when the test kit arrives then post the results.
    I understand that the FC level is a problem as well as the CYA level. After posting my readings I will need to know what problm to address first. Thank for your responses. Dennis
    You can't wait until your kit arrives to get some chlorine in your pool or it is going to turn green! Add 12 gallons of plain, unscented household bleach. That should get you up to your shock level of 25ppm. (See the Best Guess Chlorine Chart in my signature below.) With no chlorine in there and a CC reading, you've got something trying to get started. You need to start your attack now or you'll be fighting a green pool later.
    This pool is huge. It is going to be impractical for you to use bleach for the season. Does your pool store sell carboys of liquid chlorine that is either 10 or 12.5% bleach at a decent price? The other option would be to use cal-hypo for awhile until your calcium hardness gets to around 400 or so and then you'll need to switch to liquid chlorine.
    OR -- do a partial drain and refill to try and bring the CYA level down some. That might be costly to replace a lot of water, though. But, do NOT totally drain your pool or you risk floating it out of the ground if your water table is high.
  1. Day 1, where to start?
    By sturev in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-05-2010, 05:34 PM
  2. Sand filter changed @ start of season ? HIGH PRESSURE @24 PSI FROM START
    By timmygreene in forum Pool Equipment & Operations
    Last Post: 05-21-2010, 07:48 AM
  3. Where do I start first?
    By jen in tx2 in forum Dealing with Algae & Slime
    Last Post: 09-10-2009, 11:54 PM
  4. Help - where to start?
    By kevinm in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-01-2006, 07:05 PM
  5. My Start-up. What do you think?
    By Allora in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-31-2006, 08:22 PM
