Changing return location
I purchased an above ground pool that has the return located in the side of the pool next to, and about an inch below, the skimmer opening. Now that I have a heater installed, it seems like a bad location for the return as all the warm water stays on top. Is it feasible to move the return farther down the side of the pool (drill a new hole) and return the warm water closer to the bottom?
