Thread: Pool Coping Adhesive?
    Apr 2012
    New York
    Default Pool Coping Adhesive?
    My IGP is an 18 x 36 T shape that was constructed around 1983/84. The concrete coping is lose in several areas and I'm looking for ways to re-attach it. I'm not sure if this can be done with an epoxy or whether it needs to be screwed down? Whatever method is used it needs to be able handle a lot of pressure, since people often exit the pool by exerting pressure on the coping. This particular coping appears to be common during this time period. It looks like white concrete sections with small holes. I'll try to get a picture attached to this thread. Thank you.
  1. Spider gasket adhesive question
    By keljoh in forum Pool Equipment & Operations
    Last Post: 08-16-2012, 05:32 PM
  2. Cement Coping: 2 x 4 Marks in the dried coping: how to remove them?
    By Curlenjik in forum In-Ground Pool Construction and Repair
    Last Post: 01-08-2012, 07:45 PM
  3. BorderLines™ Adhesive Borders
    By Searcher in forum In-Ground Pool Construction and Repair
    Last Post: 06-02-2010, 12:57 PM
  4. New coping for SWG pool
    By jbuckste in forum In-Ground Pool Construction and Repair
    Last Post: 05-04-2009, 11:45 AM
  5. Concrete coping vs. rim lock coping
    By Sean-NJ in forum In-Ground Pool Construction and Repair
    Last Post: 08-18-2006, 04:00 PM
