Thread: Pool Opening Chemicals Needed?
    Lutherville MD
    Default Pool Opening Chemicals Needed?
    I've been a convert to this forum for a number of years and am an advocate for the BBB method. However, each year in the past I've still gone to the pool store to get "start up" chemicals. I would love to NOT do that this year (we actually just opened our pool today - I know, it's late, but what can I say!)
    What chemicals are typically necessary to have on hand to start up when you open the pool? Thanks for your help!
    BigDave's Avatar
    Default Re: Pool Opening Chemicals Needed?
    Bleach, K-2006. Test your water to see what it needs.
    We recommend Borax to raise pH, muriatic acid to lower it, baking soda to raise alk, muriatic acid and correct technique to lower it, cal-hypo as chlorination source if you need to raise calcium, stabilizer, dichlor, or trichlor if you need to raise CYA levels. You can get it all (except maybe the muriatic, the dichlor, and the trichlor) at WalMart or your local grocery store.
    Like Dave said, test your water, get a set of results, and go from there before you go shopping!
  1. Winterizing Chemicals Needed?
    By Steveromo in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 10-14-2011, 10:12 PM
  2. Opening Day Help Needed.
    By herb396 in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 05-14-2011, 10:20 PM
  3. What chemicals are needed for closing?
    By DanS in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 09-28-2008, 09:40 PM
  4. How much/which chemicals needed in newly filled pool?
    By Cold Drink in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-02-2008, 01:40 PM
  5. fall chemicals needed
    By hannadock in forum Pool Startup, Shutdown, & Winter Operation
    Last Post: 09-10-2007, 10:38 AM
