Results 1 to 10 of 12
Thread: Used Doughboy AG pool questions to help with install
    Jun 2012
    NY
    Default Used Doughboy AG pool questions to help with install
    Greeteings,
    About 5 years ago I was given a free Doughboy above ground pool which was already about 5 years old. I disassembled it and have all the parts, but I lost the notes I had on the pool size, etc. It is a larger oval pool, and now that my daughter is getting comfortable swimming I figured it is time to put up the pool. I laid out some of the side support posts with the lower wall rail so I could get an idea of size, and it looks like it is an 18'x32' pool from measuring the dimesions where the lower rail sits.
    Questions- I checked the doughboy website to get a new liner and they do not list sizes, only pool sizes. I do not see the 18x32 size listed, the smallest 18' wide oval is 34' long. If I had to get a 34' long liner would it work with the 32' pool or would it be a mess?
    Does anyone know where to get the intallation instructions for one of these pools? They do not list them on their website.
    Thanks,
    Dave
    Jun 2012
    NY
    Default Re: Used Doughboy AG pool questions to help with install
    Thanks, planned on calling today, just didnt know of one of the installers on the forum knew anything. The doughboy website does not give a lot of info, and the dealer locator does not work. I could probably wing it to assemble but it would be nice to have a layout of measurements for the support posts.
    Yeah, I think Doughboy is your best bet.
    Jun 2012
    NY
    Found a PDF file with the layout for the doughboy oval pools, based on the info my pool is actually a 32x16. It has the layout and dimensions as well as installation instructions, if you want I can post a link to it and anyone can save it for themselves.
    with the PDF file info help I will get the pool installed, just not as fast as someone who does it for a living. I will still need a liner regardless, and I am sure my next questions will be during installation, I will take pictures as it goes up. I was concerned about putting up a used pool but the doughboy pools seem to be well built and there is no corrosion on the wall sections.
    Actually, we have few installers here. I'm too hostile to pool industry standard chemistry, and it makes it uncomfortable for most loyal pool industry members. You might try asking the question at PoolSpaForum; there are more installers there, and Waterbear is a moderator there.
    But, there are a LOT more spammers and sales pitches there, so turn your sales resistance on, before you listen to responses.
    Please do post the link. I'll archive it in the index of pool literature I'm building.
    Jun 2012
    NY
    Here is the link for the doughboy oval pools
    http://www.doughboy-pools.com/Servic...G98DBSIGOL.pdf
    Here is the link for round pools
    http://www.doughboy-pools.com/Servic.../AG98DBrnd.pdf
    Good info to keep on file.
    Thanks, Rusty. Appreciate you sharing those links with us!
    Jun 2012
    NY
    No problem, glad I could find them, maybe it will save someone some time in the future. Doughboy also has videos on youtube showing the pool installations, but none of the measurements are given. With the PDF file and the video it should be straight forward.
    Went today to get the paperwork for a permit, I think that end of it is more work than the pool install!
  1. doughboy pool pump and filter choice
    By shellymatty in forum Above-Ground Pool Construction & Repair
    Last Post: 04-30-2012, 11:00 AM
  2. A couple quick install questions
    By badutahboy in forum Above-Ground Pool Construction & Repair
    Last Post: 04-29-2008, 11:48 AM
  3. PoolPilot Install Questions SC-60
    By smallpooldad in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 04-28-2008, 09:44 PM
  4. autopilot install questions
    By jmcst25 in forum Salt Generators (SWCG) & other Chlorine Feeders
    Last Post: 06-09-2007, 11:33 AM
  5. Doughboy Timberline used pool
    By zephans in forum Above-Ground Pool Construction & Repair
    Last Post: 04-15-2007, 02:19 PM
