Re: Used Doughboy AG pool questions to help with install
Found a PDF file with the layout for the doughboy oval pools, based on the info my pool is actually a 32x16. It has the layout and dimensions as well as installation instructions, if you want I can post a link to it and anyone can save it for themselves.
with the PDF file info help I will get the pool installed, just not as fast as someone who does it for a living. I will still need a liner regardless, and I am sure my next questions will be during installation, I will take pictures as it goes up. I was concerned about putting up a used pool but the doughboy pools seem to be well built and there is no corrosion on the wall sections.
