Thread: Vacuum to Waste- DE Filter
    Jun 2012
    Rhode Island
    Default Re: Vacuum to Waste- DE Filter
    There is no waste mode with a DE filter, it is not possible to bypass DE filter. Water goes into the filter from the pump and then goes back into the pool OR out of the drain valve if it is open. You can vacuum the pool with the drain valve open and the water would go straight out but it is still going through the filter and all of your DE would be sent out as well.
    @KSCronk: without a multiport valve (which many DE filters lack) it's usually not possible to vacuum to waste. I'm not sure what alternatives may exist for you but, it's much easier to answer your questions, when we know something about your pool. We often 'waste' the first few posts back and forth collecting information. So, please complete our new Pool Chart form -- it takes about 30 seconds, but will save much more than that.
    Pool Chart Entry Form
    Pool Chart Results
    @Creamy: that's true with some -- but not all -- DE & cartridge filters.
    Hey, welcome to The Forum!
    Tomorrow I'll write up something on bypassing or vacuuming to waste DE filters without a multiport.
