Results 1 to 10 of 14
Thread: Just joined the forum
    Default Re: Just joined the forum
    OK. Good. When I saw he had entered it all above, I thought maybe it had been put here instead of in the chart. I shoulda looked! Thanks, Anna.
    Jun 2012
    Minnesota
    Cool Re: Just joined the forum
    I promise, I did do my homework.
    K2006 will be here soon. We were out in the pool today, and my wife commented on the fact that she could tell I used "store brand" chlorine because it smells different from Clorox or the stuff I used to get at the pool store. I told her I was only doing as instructed and once the level goes down, she won't smell it at all.
    It didn't keep us from swimming for 2 hours, so it couldn't have been that big of a deal.
    You really shouldn't be able to smell the chlorine at all. Usually when someone is smelling that chlorine smell it means they have a CC reading and actually need more chlorine to break it down. When you get the kit, post a full set of numbers and we'll have a look and see if anything needs tweaked.
    Glad you had a good day in the pool. That is what it is all about!
    (By the way -- reassure your wife that the store brand chlorine is fine. I don't think my pool has ever had anything but Walmart's generic bleach in it.)
    Jun 2012
    Minnesota
    I can't smell it at all...I think she's just paranoid that we're changing the way the pool is maintained. We'll be fine...
    Jun 2012
    Minnesota
    So we've had a boatload of rain here the last few days - I have had to empty water out of the pool several times to keep it from going above the skimmers. Chlorine this morning is <1.0 ppm and pH is around 7.8. Clearly I need to add bleach, but how much? And what to do about the pH at this point? I did not test the TA as I am running a tad late this morning.
    Lehigh Valley, PA
    1 gallon of 6% bleach adds 6 ppm FC to 10,000 gallons. Calculate that out for your volume. Don't worry about the pH. It's still in range and may drift down again. What's your CYA these days?
    Jun 2012
    Minnesota
    Quote Originally Posted by AnnaK View Post
    CYA = 90
    TA = 140
    I've not added any pucks, so there should be nothing adding CYA anymore. I added 3 jugs of 6% 96oz chlorine. And removed 7-8 frogs or parts of frogs from the skimmers.
    I'll retest in the morning and if need be can add another jug. Should be swimmable by afternoon I would think.
  1. New guy just joined
    By jbg108 in forum Above-Ground Pool Construction & Repair
    Last Post: 09-04-2012, 03:45 PM
  2. New to forum
    By KFollen in forum Above-Ground Pool Construction & Repair
    Last Post: 06-20-2012, 08:49 PM
  3. New to the forum
    By Richs154 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2012, 06:18 PM
  4. Just joined -- planning new pool
    By Betty in forum In-Ground Pool Construction and Repair
    Last Post: 05-27-2012, 09:15 AM
