Results 1 to 4 of 4
Thread: foamy
    Jun 2012
    Massachusetts
    Default foamy
    Hi All just joined the forum opened the pool today PH was low ,added some borax as usual then added some "bargain " algecide now the surface is all foamy , going to try to add some water and run the filter all night any suggestions
    Default Re: foamy
    Cheap algaecides will do that.....I would shock the pool and let the filter do the rest...
    Welcome to the forum!!
    Jun 2012
    Massachusetts
    Default Re: foamy
    yup all nighter with the filter and some new water and all is well no more "bargains"
    Default Re: foamy
    Good! That is one of the main reasons we advise only using Polyquat 60% when you need to add algaecide. Foaming is a common side effect of other ones as you unfortunately learned the hard way! Glad it is getting better.
  1. foamy pool
    By cruzadin1121 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-10-2012, 04:25 PM
  2. Green, cloudy and foamy is no way to go through life, son
    By davidb in forum Dealing with Algae & Slime
    Last Post: 08-01-2011, 12:11 AM
  3. foamy water
    By DrSteveF in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-21-2011, 08:35 PM
  4. My Screw UP = Foamy Mess
    By lm8838 in forum Dealing with Algae & Slime
    Last Post: 06-07-2008, 04:54 PM
  5. foamy bubbles?
    By bhelme in forum Pool Chemicals & Pool Water Problems
    Last Post: 05-26-2007, 10:21 AM
