Thread: foamy
    Jun 2012
    Massachusetts
    Default foamy
    Hi All just joined the forum opened the pool today PH was low ,added some borax as usual then added some "bargain " algecide now the surface is all foamy , going to try to add some water and run the filter all night any suggestions
    Default Re: foamy
    Cheap algaecides will do that.....I would shock the pool and let the filter do the rest...
    Welcome to the forum!!
    Jun 2012
    Massachusetts
    Default Re: foamy
    yup all nighter with the filter and some new water and all is well no more "bargains"
    Default Re: foamy
    Good! That is one of the main reasons we advise only using Polyquat 60% when you need to add algaecide. Foaming is a common side effect of other ones as you unfortunately learned the hard way! Glad it is getting better.
