Thread: Pool Store Test Results
    Phulish Guest
    Default Pool Store Test Results
    Haven't taken the cover off yet, but wanted to get a general idea of where things are at underneath. Took a sample over to the pool store and will test with my PS kit this evening to confirm.
    32K Gallon, Inground Vinyl Liner
    FC 0
    TC 0
    PH 7.0
    TA 90
    CYA 10
    Hardness 120
    Metals 0
    I am planning on removing the cover tomorrow night and shocking the pool with about 7 gallons of bleach.
    Also will add about 3 lds of soda ash
    and finally add about 7lds of CYA (start with about 4 then wait a week)
    any comments? Once I shock the pool how soon after can i begin to tackle the PH and CYA? or should the PH be my main concern?
    I assume I should keep Alk where it is as it is in the 80 - 125 range and the hardness is fine as I have a vinyl liner.
    Thanks in advance!
    duraleigh Guest
    Default Re: Pool Store Test Results
    It looks to me like you've done your homework. I don't have the calc handy for a 32k pool but your quantities and your plan both make good sense.
    Phulish Guest
    thanks Dave, i have been visiting these boards for awhile now and this is the 1st year I feel like I am ready to tackle it all.
    As for my question, cani tackle all 3 issues at once (i.e. bleach at shock level, soda ash and stabilizer in a sock near the return) or should I focus on individual issues?
    There's no reason I can see why you can't do all three at once, just don't combine the chemicals unless they're in the water.
  1. Pool Store vs Test Kit Results??
    By hawkeye91 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-16-2010, 10:58 AM
  2. Pool Store Test Results
    By LFRoberts5 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 07-19-2007, 05:35 PM
  3. My test results vs. Pool Store...now what??
    By Henrys514 in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-16-2006, 01:32 AM
  4. Test Results from pool store
    By jrtvols in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-02-2006, 02:59 PM
  5. pool store test results
    By fullhouse in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 05-01-2006, 06:20 PM
