Closed Thread
Thread: bad spot in shallow end
    Scottsdale, Arizona
    Default Re: bad spot in shallow end
    Is it hollow under the spot ?
    Call your contractor to come inspect it since it's a new pool .
    Dec 2005
    Denham Springs, Louisiana, USA.
    Yes it is hollow under the spot. When I push down with my toe I can't feel anything under the liner.
    Kentucky
    I would certianly have your contractor come 'look' at it. If it's actually on the bottom - there's not much that can be done other than draining the pool, and pulling the liner back to repair the hole.
    I have a few of these on my Vinyl IG where the slope into the deep end meets the hopper wall. They are soft - but not totally hollow. The builder stated that they could fix them (draining more than 1/2 my water, and the _possiblity_ that I would have problems getting the liner to go back in 'just right').
    He said however that it most likely wouldn't cause any problem unless it got larger.
    That said - i live in a fairly wet area, and it's likely that just a small area on that particluar spot has sunk in due to water behind the wall (high water table). If you live in an especially wet area this could also be the case - but since the pool is brand new - I would be concerned.
    My main concern would be a pinhole in the liner that could be leaking water at that spot, causing the sink hole.
    Good luck.
    Dec 2005
    Thank you for your help. I have a call into my pool builder
Closed Thread
