Results 1 to 9 of 9
Thread: How much does liquid 6% Chlorine change PH
Threaded View
  1. #4
    mas985's Avatar
    Pleasanton, CA
    Default Re: How much does liquid 6% Chlorine change PH
    Quote Originally Posted by mwsmith2
    Hm. I would expect the pH to go up, not down. You sure that formula is correct?
    Michael
    Sorry, I made an approximation. The proper solution is:
    -log10(10^(-7.4)*10000/10001+10^(-12)*1/10001) = 7.4000434261859642546351588394264
    And this equation is really only good for solutions without buffers so it is not that accurate for a swimming pool but I do believe it is a worst case.
    Mark
  1. Liquid Chlorine?
    By proximo in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 04-01-2013, 11:48 AM
  2. liquid chlorine
    By mrs.rainbow in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-30-2011, 10:24 AM
  3. How / Where Do I buy Liquid Chlorine?
    By cheshamjim in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 06-29-2007, 05:06 PM
  4. Liquid shock, bleach, liquid chlorine?
    By rollinrock in forum Using Chlorine and Chlorinating Chemicals
    Last Post: 05-30-2007, 01:26 PM
  5. Odd Color Change when Testing for Chlorine
    By RudyandRocky in forum Testing and Adjusting Pool Water Chemistry
    Last Post: 06-19-2006, 07:04 PM
